- Define the vendor option.
- Create the vendor class.
Perform this procedure to configure vendor option data for a vendor class.
The switch follows inheritance and precedence rules for configured DHCP Server options.
The switch process the DHCP options in the following order of precedence:
- host—Host configuration applies only to a specific host.
- DHCP subnet—DHCP subnet options apply to only those clients within the specified subnet.
- vendor class—Vendor class options apply to only those clients with a string that matches a specified vendor class identifier (VCI).
- global—Global options apply to all clients.
DHCP Server builds a cumulative configuration from all scopes but applies precedence rules in instances of conflict.
- Select DHCP Server.
- Select the Vendor Class Vendor Option tab.
- Select Insert.
- In ID, type the DHCP code that you defined for the vendor option.
- In Vendor class id, type the value to apply to the vendor option.
- In Value, type the value to assign to the vendor option.
- Select Insert.
Vendor Class Vendor Option Field Descriptions
Use the data in the following table to use the Vendor Class Vendor Option tab.
Name | Description |
ID |
Specifies the vendor class ID. |
Code |
Specifies the DHCP code that identifies the vendor option. |
Value |
Specifies a data value to apply to this vendor class. |
